Hi!
Do you know a way how to get aattachment data that is add to a comment? Today I found that adding attachment to a comment don't start Field change value trigger set for attachment field. Now I'm looking a way how I can cover this scenario. Any thoughts?
Seba
Yes this can be possible through automation, iam using same automation rule it works for me
smart value:{{issue.comments}}
Hope this helps
@Sebastian Krzewiński if it helps to you can you hit accept answer so that other can reach and it will help to others those who needs this automation.
To comments there are two triggers that you can be use: comment.update and comment.created.
You can use them to get the attachments data in the comment.
But, if the attachment will be insert in issue outside comment, you could use:
As indicated on:
Hope this helps.
I found that in some cases Field value changed don't work correctly - https://jira.atlassian.com/browse/AUTO-382
