Get back to legacy Jira Cloud navigation
Richard Ryan
I wanted to try the new Jira navigation - I didn't want to be STUCK in it. How do get back?
John Funk
April 16, 2020
Hi Richard,
Click on your avatar in the top right.
Then select Turn off the New Navigation.
Richard Ryan
Yeah that does it - why is that under my avatar rather than under the Jira software icon in the upper left hand corner?   Or why not put the option both places rather than make me guess?  Just askin'.....
John Funk
April 19, 2020
No idea why they decided to put it where they did, other than it is a personal setting just like the New Jira Issue view. Guess they figured that was related.
Richard Ryan
Ok - thanks for the response.  Doesn't seem intuitive but I appreciate you following up.
John Funk
April 20, 2020
Glad I could help.
Kate June 10, 2020
How there's no Turn off the New Navigation option under avatar. Is there any way to remove it?
John Funk
June 10, 2020
My understanding is that all instances will be moved to the new top navigation and the old one will no longer be accessible. So the short answer is no you cannot go back anymore.
Like Tim Dong likes this
FREE
