I was getting error on Create issue error msg from Jira is as below
"errorMessages": [
"JD user picker: JD user picker is required.",
"JD issue date: JD issue date is required.",
"JD version picker multiple: JD version picker multiple is required.",
"JD issue URL: JD issue URL is required.",
"JD Issue multiple list: JD Issue multiple list is required.",
"JD Issue single list: JD Issue single list is required.",
"JD Group Picker single: JD Group Picker single is required.",
"JD Group picker: JD Group picker is required.",
"JD issue detailed description: JD issue detailed description is required.",
"JD issuing team: JD issuing team is required.",
"JD issue time: JD issue time is required.",
"JD issue type: JD issue type is required.",
"JD issue single line description: JD issue single line description is required.",
"JD version picker single: JD version picker single is required."
"errors": {}
but when we do get call for get fields for issuetype bug will not get such fields is response as mention in above error
"expand": "projects",
"projects": [
"expand": "issuetypes",
"self": "https://mydomain.atlassian.net/rest/api/2/project/10114",
"id": "10114",
"key": "JTD",
"name": "Jira-Test-Development",
"avatarUrls": {
"48x48": "https://mydomain.atlassian.net/rest/api/2/universal_avatar/view/type/project/avatar/10490",
"24x24": "https://mydomain.atlassian.net/rest/api/2/universal_avatar/view/type/project/avatar/10490?size=small",
"16x16": "https://mydomain.atlassian.net/rest/api/2/universal_avatar/view/type/project/avatar/10490?size=xsmall",
"32x32": "https://mydomain.atlassian.net/rest/api/2/universal_avatar/view/type/project/avatar/10490?size=medium"
"issuetypes": [
"self": "https://mydomain.atlassian.net/rest/api/2/issuetype/10004",
"id": "10004",
"description": "A problem which impairs or prevents the functions of the product.",
"iconUrl": "https://mydomain.atlassian.net/rest/api/2/universal_avatar/view/type/issuetype/avatar/10303?size=medium",
"name": "Bug",
"untranslatedName": "Bug",
"subtask": false,
"expand": "fields",
"fields": {
"summary": {
"required": true,
"schema": {
"type": "string",
"system": "summary"
"name": "Summary",
"key": "summary",
"hasDefaultValue": false,
"operations": [
"set"
"parent": {
"required": false,
"schema": {
"type": "issuelink",
"system": "parent"
"name": "Parent",
"key": "parent",
"operations": [
"set"
"issuetype": {
"required": true,
"schema": {
"type": "issuetype",
"system": "issuetype"
"name": "Issue Type",
"key": "issuetype",
"operations": [],
"allowedValues": [
"id": "10004",
"name": "Bug",
"subtask": false,
"avatarId": 10303,
"hierarchyLevel": 0
"components": {
"required": false,
"schema": {
"type": "array",
"items": "component",
"system": "components"
"name": "Components",
"key": "components",
"operations": [
"add",
"set",
"remove"
"allowedValues": [
"self": "https://mydomain.atlassian.net/rest/api/2/component/10069",
"id": "10069",
"name": "JD component 2"
"self": "https://mydomain.atlassian.net/rest/api/2/component/10068",
"id": "10068",
"name": "JD sample components"
"self": "https://mydomain.atlassian.net/rest/api/2/component/10070",
"id": "10070",
"name": "test"
"self": "https://mydomain.atlassian.net/rest/api/2/component/10071",
"id": "10071",
"name": "uhuh"
"project": {
"required": true,
"schema": {
"type": "project",
"system": "project"
"name": "Project",
"key": "project",
"operations": [
"set"
"allowedValues": [
"id": "10114",
"key": "JTD",
"projectTypeKey": "software",
"simplified": false,
"avatarUrls": {
"projectCategory": {
"self": "https://mydomain.atlassian.net/rest/api/2/projectCategory/10000",
"id": "10000",
"description": "All projects in the Product department",
"name": "Product"
"description": {
"required": false,
"schema": {
"type": "string",
"system": "description"
"name": "Description",
"key": "description",
"operations": [
"set"
"customfield_10010": {
"required": false,
"schema": {
"type": "array",
"items": "json",
"custom": "com.pyxis.greenhopper.jira:gh-sprint",
"customId": 10010
"name": "Sprint",
"key": "customfield_10010",
"operations": [
"set"
"reporter": {
"required": true,
"schema": {
"type": "user",
"system": "reporter"
"name": "Reporter",
"key": "reporter",
"autoCompleteUrl": "https://mydomain.atlassian.net/rest/api/2/user/search?query=",
"hasDefaultValue": true,
"operations": [
"set"
"fixVersions": {
"required": false,
"schema": {
"type": "array",
"items": "version",
"system": "fixVersions"
"name": "Fix versions",
"key": "fixVersions",
"operations": [
"set",
"add",
"remove"
"allowedValues": [
"self": "https://mydomain.atlassian.net/rest/api/2/version/10010",
"id": "10010",
"name": "JD version",
"archived": false,
"released": false,
"projectId": 10114
"self": "https://mydomain.atlassian.net/rest/api/2/version/10011",
"id": "10011",
"name": "JD version 2",
"archived": false,
"released": false,
"projectId": 10114
"priority": {
"required": true,
"schema": {
"type": "priority",
"system": "priority"
"name": "Priority",
"key": "priority",
"operations": [
"set"
"allowedValues": [
"self": "https://mydomain.atlassian.net/rest/api/2/priority/2",
"iconUrl": "https://mydomain.atlassian.net/images/icons/priorities/high.svg",
"name": "High",
"id": "2"
"self": "https://mydomain.atlassian.net/rest/api/2/priority/3",
"iconUrl": "https://mydomain.atlassian.net/images/icons/priorities/medium.svg",
"name": "Medium",
"id": "3"
"self": "https://mydomain.atlassian.net/rest/api/2/priority/4",
"iconUrl": "https://mydomain.atlassian.net/images/icons/priorities/low.svg",
"name": "Low",
"id": "4"
"defaultValue": {
"name": "Medium",
"id": "3"
"customfield_10178": {
"required": false,
"schema": {
"type": "array",
"items": "option",
"custom": "com.atlassian.jira.plugin.system.customfieldtypes:multicheckboxes",
"customId": 10178
"name": "impediment_2",
"key": "customfield_10178",
"operations": [
"add",
"set",
"remove"
"allowedValues": [
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10083",
"value": "true",
"id": "10083"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10084",
"value": "false",
"id": "10084"
"customfield_10256": {
"required": false,
"schema": {
"type": "option",
"custom": "com.atlassian.jira.plugin.system.customfieldtypes:select",
"customId": 10256
"name": "Company Name",
"key": "customfield_10256",
"operations": [
"set"
"allowedValues": [
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10241",
"value": "2degrees",
"id": "10241"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10242",
"value": "Abbott Laboratories",
"id": "10242"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10243",
"value": "Admiral Group",
"id": "10243"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10244",
"value": "Allegion plc",
"id": "10244"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10245",
"value": "Ally Financial",
"id": "10245"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10246",
"value": "BC Government - Natural Resource Ministries",
"id": "10246"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10247",
"value": "BHP",
"id": "10247"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10248",
"value": "Blackrock",
"id": "10248"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10249",
"value": "BNY Mellon",
"id": "10249"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10250",
"value": "Carrier",
"id": "10250"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10251",
"value": "Charles Schwab & Co., Inc.",
"id": "10251"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10252",
"value": "Clarivate Technologies",
"id": "10252"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10253",
"value": "Cognizant",
"id": "10253"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10254",
"value": "Cvent",
"id": "10254"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10255",
"value": "CVS Health",
"id": "10255"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10256",
"value": "cxLoyalty div of JPMC",
"id": "10256"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10257",
"value": "Disney",
"id": "10257"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10258",
"value": "DTCC",
"id": "10258"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10259",
"value": "Eaton",
"id": "10259"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10260",
"value": "Estee Lauder",
"id": "10260"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10261",
"value": "Finastra",
"id": "10261"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10262",
"value": "Ford Motor Company",
"id": "10262"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10263",
"value": "Freddie Mac",
"id": "10263"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10264",
"value": "General Atomics",
"id": "10264"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10265",
"value": "HCA Holdings, Inc.",
"id": "10265"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10266",
"value": "Highmark",
"id": "10266"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10267",
"value": "Humana",
"id": "10267"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10268",
"value": "Intuit",
"id": "10268"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10269",
"value": "Kaiser Permanente",
"id": "10269"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10270",
"value": "Las Vegas Sands",
"id": "10270"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10271",
"value": "Lenovo",
"id": "10271"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10272",
"value": "Liberty Mutual Insurance Company HQ",
"id": "10272"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10273",
"value": "Marriott",
"id": "10273"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10274",
"value": "Marsh & Mclennan Companies",
"id": "10274"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10275",
"value": "McKesson Corporation",
"id": "10275"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10276",
"value": "Medtronic",
"id": "10276"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10277",
"value": "Mercedes Benz Financial",
"id": "10277"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10278",
"value": "Molina Healthcare, Inc.",
"id": "10278"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10279",
"value": "Omnicell, Inc,",
"id": "10279"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10280",
"value": "PNC",
"id": "10280"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10281",
"value": "PT Bank Danamon Indonesia",
"id": "10281"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10282",
"value": "Smith & Nephew",
"id": "10282"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10283",
"value": "SONY Corporation of America",
"id": "10283"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10284",
"value": "Starbucks",
"id": "10284"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10285",
"value": "TAL",
"id": "10285"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10286",
"value": "Telecom Technology Center - TTC",
"id": "10286"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10287",
"value": "Telefonica",
"id": "10287"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10288",
"value": "Telus",
"id": "10288"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10289",
"value": "Test Account",
"id": "10289"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10290",
"value": "The TJX Companies",
"id": "10290"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10291",
"value": "Tik Tok",
"id": "10291"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10292",
"value": "University of Melbourne",
"id": "10292"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10293",
"value": "Zebra Technologies Corporation",
"id": "10293"
"self": "https://mydomain.atlassian.net/rest/api/2/customFieldOption/10294",
"value": "ZOLL Medical Corporation",
"id": "10294"
"labels": {
"required": false,
"schema": {
"type": "array",
"items": "string",
"system": "labels"
"name": "Labels",
"key": "labels",
"autoCompleteUrl": "https://mydomain.atlassian.net/rest/api/1.0/labels/suggest?query=",
"operations": [
"add",
"set",
"remove"
"environment": {
"required": false,
"schema": {
"type": "string",
"system": "environment"
"name": "Environment",
"key": "environment",
"operations": [
"set"
"customfield_10008": {
"required": false,
"schema": {
"type": "any",
"custom": "com.pyxis.greenhopper.jira:gh-epic-link",
"customId": 10008
"name": "Epic Link",
"key": "customfield_10008",
"operations": [
"set"
"attachment": {
"required": false,
"schema": {
"type": "array",
"items": "attachment",
"system": "attachment"
"name": "Attachment",
"key": "attachment",
"operations": [
"set"
"versions": {
"required": false,
"schema": {
"type": "array",
"items": "version",
"system": "versions"
"name": "Affects versions",
"key": "versions",
"operations": [
"set",
"add",
"remove"
"allowedValues": [
"id": "10010",
"archived": false,
"released": false,
"projectId": 10114
"id": "10011",
"archived": false,
"released": false,
"projectId": 10114
"issuelinks": {
"required": false,
"schema": {
"type": "array",
"items": "issuelinks",
"system": "issuelinks"
"name": "Linked Issues",
"key": "issuelinks",
"autoCompleteUrl": "https://mydomain.atlassian.net/rest/api/2/issue/picker?currentProjectId=&showSubTaskParent=true&showSubTasks=true¤tIssueKey=null&query=",
"operations": [
"add"
"assignee": {
"required": false,
"schema": {
"type": "user",
"system": "assignee"
"name": "Assignee",
"key": "assignee",
"autoCompleteUrl": "https://mydomain.atlassian.net/rest/api/2/user/assignable/search?project=JTD&query=",
"operations": [
"set"
what is the solution for this?
Try a simple test - log in as the user you are using for the REST call, and try creating the issue in the UI.
I think you'll find all those fields are missing from the create issue screen, and if you try to create an issue, it will fail with a load of "mandatory field missing" errors, the same as your REST call.
