Getting this error while using swagger generated as discussed in this URL, Could anyone please take a look and suggest any workaround for this?
It would be a great help if you could help with this issue?
Attaching Stack Trace and possible reasons due to which it is being generated.
https://elmah.io/tools/stack-trace-formatter/80eb332a6f7a4fc7a65cb5c6a9ee7e1a
Basically, the discriminator being generated is empty, how to solve this?
return getClassByDiscriminator(
classByDiscriminatorValue,
getDiscriminatorValue(readElement, ""));
As mentioned by @Chandim Chatterjee this seems to be a known bug in swagger-codegen. https://github.com/swagger-api/swagger-codegen/issues/10196
I guess the solution for now is to use openapi-generator if this bug affects you, or else wait for the fix for swagger-codegen to be released.
What URL/API are you accessing? It's hard to get any context here.
Also, it looks like you are running a test that is failing. I don't think you can run the generated tests without modification.
What modification do I need to make, like added API token and userName getting data, but the problem occurs in deserialization of Data as swagger is creating multiple implementations, but doesn't give any discriminator.
Perhaps you could indicate what options you used to to generate your library, and give some sample code you are calling that is failing.
Code Failing here while deserialization of data while trying to run Tests
public static GsonBuilder createGson() {
GsonFireBuilder fireBuilder = new GsonFireBuilder()
.registerTypeSelector(UserDetails.class, new TypeSelector<UserDetails>() {
@Override
public Class<? extends UserDetails> getClassForElement(JsonElement readElement) {
Map<String, Class<? extends UserDetails>> classByDiscriminatorValue = new HashMap<>();
classByDiscriminatorValue.put("AllOfAttachmentAuthor".toUpperCase(), AllOfAttachmentAuthor.class);
classByDiscriminatorValue.put("AllOfChangelogAuthor".toUpperCase(), AllOfChangelogAuthor.class);
classByDiscriminatorValue.put("AllOfCommentAuthor".toUpperCase(), AllOfCommentAuthor.class);
classByDiscriminatorValue.put("AllOfCommentUpdateAuthor".toUpperCase(), AllOfCommentUpdateAuthor.class);
classByDiscriminatorValue.put("AllOfEventNotificationUser".toUpperCase(), AllOfEventNotificationUser.class);
classByDiscriminatorValue.put("AllOfFieldsAssignee".toUpperCase(), AllOfFieldsAssignee.class);
classByDiscriminatorValue.put("AllOfWorklogAuthor".toUpperCase(), AllOfWorklogAuthor.class);
classByDiscriminatorValue.put("AllOfWorklogUpdateAuthor".toUpperCase(), AllOfWorklogUpdateAuthor.class);
classByDiscriminatorValue.put("UserDetails".toUpperCase(), UserDetails.class);
private static <T> Class<? extends T> getClassByDiscriminator(Map<String, Class<? extends T>> classByDiscriminatorValue, String discriminatorValue) {
Class<? extends T> clazz = classByDiscriminatorValue.get(discriminatorValue.toUpperCase());
if(null == clazz) {
throw new IllegalArgumentException("cannot determine model class of name: <" + discriminatorValue + ">");
return clazz;
private static String getDiscriminatorValue(JsonElement readElement, String discriminatorField) {
JsonElement element = readElement.getAsJsonObject().get(discriminatorField);
if(null == element) {
throw new IllegalArgumentException("missing discriminator field: <" + discriminatorField + ">");
return element.getAsString();
swagger-codegen generate \
-i ./swagger-v3.v3.json \
-l java \
-o ~/src/jira-client
Config.json
"modelPackage": "com.spr.jira.rest.client.model",
"apiPackage": "com.spr.jira.rest.client.api",
"invokerPackage": "com.spr.jira.rest.client",
"library": "jersey2",
"groupId": "com.spr.jira.rest",
"artifactId": "client"
I get quite different code for the same config/command. I only see this method signature in client/JSON.java:
But the method I get looks like:
return fireBuilder.createGsonBuilder();
I'm using swagger-codegen 3.0.16 and the latest swagger-v3.v3.json
I got the same issue as OP and getting this exception whenever I try to fetch the changelog. @David Smith were you able to figure out this issue?
@Chandim Chatterjee how did you generate the source for your client? (e.g. which version of swagger-codegen, and did you use the latest published swagger spec) Can you confirm you're requesting this from a Jira Cloud site (and not Server or Data Centre)? (FWIW I can't see the original stack trace any more, so I can't see the actual error any more.)
I used the spec available on this site: https://developer.atlassian.com/cloud/jira/platform/rest/v3/intro/ and my swagger-codegen version is 3.0.41.
This is the config I used in generating the client in java:
"modelPackage": "com.squareup.jira.cloud.rest.client.model",
"apiPackage": "com.squareup.jira.cloud.rest.client.api",
"invokerPackage": "com.squareup.jira.cloud.rest.client",
"library": "retrofit2",
"groupId": "com.squareup.jira.cloud.rest",
This is the error I get:
missing discriminator field: <>
java.lang.IllegalArgumentException:
at com.squareup.jira.cloud.rest.client.JSON.getDiscriminatorValue(JSON.java:983)
at com.squareup.jira.cloud.rest.client.JSON$53.getClassForElement(JSON.java:387)
at io.gsonfire.gson.TypeSelectorTypeAdapterFactory$TypeSelectorTypeAdapter.read(TypeSelectorTypeAdapterFactory.java:65)
at io.gsonfire.gson.NullableTypeAdapter.read(NullableTypeAdapter.java:36)
at io.gsonfire.gson.HooksTypeAdapter.deserialize(HooksTypeAdapter.java:86)
at io.gsonfire.gson.HooksTypeAdapter.read(HooksTypeAdapter.java:54)
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.readIntoField(ReflectiveTypeAdapterFactory.java:212)
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$FieldReflectionAdapter.readField(ReflectiveTypeAdapterFactory.java:433)
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:393)
at retrofit2.converter.gson.GsonResponseBodyConverter.convert(GsonResponseBodyConverter.java:40)
at retrofit2.converter.gson.GsonResponseBodyConverter.convert(GsonResponseBodyConverter.java:27)
at retrofit2.OkHttpCall.parseResponse(OkHttpCall.java:243)
at retrofit2.OkHttpCall.execute(OkHttpCall.java:204)
Looking at the auto-generated code, I see a similar error as what @David Smith found.
I believe this may be an existing error in swagger-codegen according to this bug which has been only recently fixed: https://github.com/swagger-api/swagger-codegen/issues/10196
Great find @Chandim Chatterjee . I agree - it's probably the swagger-codegen bug you linked. There's a comment there that openapi-generator works OK, or else I guess you could wait for the bug fix.
Hi, Could anyone help in this, or mention what more context should I provide ?
Using openapi codegen (java jar version) instead of swagger-codegen produced code that seems to work fine for me, getting my worklog hours mostly. Have not tested everything, but at least no up-front hacking required.
Switch the -l java option with -g java, other options in use here are the same.
Used Java 8 to build it.
Register now
