Here's an outline of what I want automated:
The Fix Version field on the linked SD project issues is not being set.
Here's what my rule looks like:
And here's the audit log:
Versions are defined at a project level. For this multi-project rule, have you confirmed that in the destination project (SD) you already have a version with the same name?
Best regards,
Thanks Bill! You rock. That was the problem. The same version # was not defined in the SD project.
It's working now!
Register now
