Global Components available across all Jira projects?
Yana Nikolayeva July 31, 2020
I have a need to set a list of Components that will be available across all Jira projects. It is possible? Or I need to redo it for each Project ?
Nikki Zavadska _Appfire_
Hi @Yana Nikolayeva
global components aren't available in Jira by default. There is the improvement request pending for this from 2005 you can vote for it here.
For now, you need to create them in each of the projects manually, give them the same name and then you can use JQL as usual.
If you want to make sure that these components stay in sync you can use the app or again, do it manually.
Here is quick post I wrote on this topic
👉 https://community.atlassian.com/How-do-you-share-components-across-the-projects
I hope this helps,
Nikki
Thank you very much Nikki!
Like • Nikki Zavadska _Appfire_ likes this
Gregory Carman
In case anyone stumbles across this issue, you can use an app called Octo Component Management. This will allow you to create component and apply it to multiple projects at the same time. Hope this helps!
I found same questions raised back to 2016 https://community.atlassian.com/t5/Jira-Core-questions/Share-Components-across-Projects/qaq-p/341128 and back then answer was:
" ... components are local to projects. .... Atlassian have said it's something they want to do, but we have no timescales I'm afraid...." 4 years later - Atlassian team - ANY UPDATES?  :)
Help us plant more trees
