×This question is in reference to Atlassian Documentation: View, create, or delete a group
This article mentions that before you delete a group, it is a good idea to: "Check whether the group is being used by any permission schemes, email notification schemes, issue security levels, or saved filters."
When I view a particular group in our JIRA Cloud instance, no usage information is displayed. Is there another way to get this information before I delete a group?
This is not currently supported by Atlassian in Cloud, which is very frustrating. I'd recommend voting for the issue to gain support: https://jira.atlassian.com/browse/JRACLOUD-36740
@Grayson Bishop any idea how can I find out number of projects which are using any specific group for JIRA cloud? Thanks!
Hey @Narendra Kumar, we were able to request a report from Atlassian support with every place a specific group is used. They weren't able to map out our entire instance, but they seemed willing to pull this report for handful of groups.
The report included all dashboards, filters, project roles, and permissions shared with/assigned to that group
HI Alex,
In standard JIRA it is easy:
https://confluence.atlassian.com/jirakb/how-to-identify-group-usage-in-jira-441221524.html
In cloud you can always create a dummy user and add him to groups which you would like to check. I don't know more sophisticated method to check it in cloud JIRA.
Regards
How would adding a dummy user help me check how the group is being used? I'm looking to see if the group is being used by any permission schemes, email notification schemes, issue security levels, or saved filters.
If you add a dummy user to a group, you can see, via the "View Jira Project Roles" in the User Management screen for the dummy user, which project roles it has inherited for each project. This doesn't show you which email notification schemes, issue security levels, or saved filters the group is being used by, but it does give you some information about which projects are associated with the group and is a starting point.
Hey @Vicki Lea Tsang it's not clear for me. Could you please let me know something more about it in details. Thanks in advance!!
