Help! I've changed a user story into and epic and cant find it?
ashley.frost April 20, 2020
As above, I had a story that was too meaty and so changed it's type to an Epic. I can no longer locate the story/epic - I'm sure it's just something I've not learned yet, but it's frustrating me!
Any help very welcome right now.
John Funk
Hi Ashley,
Do you remember the key/id for the issue? Do you have any kind of email that might have that?
If so, simply go to the search bar and type in the key/id and hit search - it should find it for you.
The other option is to search for it by writing a filter.
Go to the filter section and type
Project = ABC and issuetype = Epic
That will get you a list of all epics for that project and maybe you can find it.
HI - I know that the original no. was 250, however if i search my backlog, it only seems to show stories/bugs an not epics. If Iswitch on the epics pane... ahh I've found it as an 'unlabelled epic" !!
Thank you for your assistance, I got it one way or another.... lots to learn !
John Funk
Great! Glad you were able to find it.  :-)
Like ashley.frost likes this
Let's build A Rovo Agent 🤖
Save your spot
