I'm trying to figure out a Smart Value for Jira Automation rule. The rule alerts the appropriate Slack channel when a ticket is transitioned from 1 project to another. It works well, but I would like to include the prior project into the Slack message.
So, I'm wondering if someone can help me determine the Smart Value from the changelog for the items I'm pointing to.
To close this question, I change the rule as I mentioned above and it triggered last night and operated as expected. I need to correct my wording a bit, but that is an easy fix.
The smart value I was looking for was:
{{changelog.project.fromString}}
The whole Slack message is
*{{initiator.displayName}} moved a {{issueType.name}} from the {{changelog.project.fromString}} Project to the {{changelog.project.toString}} Project*
<https://company.atlassian.net/browse/{{issue.key}}|{{issue.key}} {{issue.summary}}>
*Priority:* {{issue.priority.name}}
*Labels:* {{#issue.labels}}{{.}}, {{/}}
*Reporter:* {{issue.fields.reporter.displayName}}
*Description:* {{issue.description.abbreviate(300)}}
I answered a similar question here few weeks ago.
You can use Automation to call Jira REST API with changelog.
JIRAURL/rest/api/3/issue/{{issue.key}}?expand=changelog
Then you can access changelog like this.
{{webhookResponse.body.changelog.histories}}
You can iterate this using this.
{{#webhookResponse.body.changelog.histories}}
Created: {{created}}
{{#items}}{{fromString}} - {{toString}} {{/}}
Which will give you output like this.
Created: 2021-01-02T17:11:59.730+0000
To Do - In Progress
Created: 2021-01-01T16:40:30.859+0000
To Do - In Review
I hope it helps. I know there are multiple steps involves and calling Jira REST API will involving storing Authentication information as plain text which is not ideal.
Or you can also try using ScriptRunner for Jira Cloud where fetching change history and parsing the JSON in Groovy is much simpler and with script you can achieve lot more.
I hope it helps.
Ravi
Thank you for your response @Ravi Sagar _Sparxsys_ ,
I was able to access the changelog status using the following in Jira Automation
{{changelog.status.fromString}}
So, I was hoping to find a similar variable that I could use to get something similar and I think that I was able to accomplish it by really thinking about what you wrote and what I could do, so I think that line I was looking for is
