Help with these questions
vashim shekh
Scenario 1:
  • We are currently running 12 projects, with 3 project managers, and 9 developers
  • These projects are all running in sprints, and have sprints planned for the next 6 weeks
  • We want to determine how much time is estimated per person, per sprint, for each planned sprint
  • We also want to know how much work is in those projects that are not part of the sprint
  • We also want to know how much work per sprint is planned across projects for each project manager (How many hours of work are they managing in each sprint?)
  • Additionally, 10 of those 12 projects are Time & Materials billing. We specifically want to know how many hours of T&M work are planned in each sprint, compared to non-T&M work for each sprint.
Karim ABO HASHISH
May 21, 2023 edited
hi @vashim shekh
According to your needs, I would recommend trying one of the below plugins (non-biased opinion) based on least effort approach.
Option 1
Resource Planning, Project Management, Gantt Chart for Jira
This plugin will be free for your current plan, i didn't personally try it but i recommend it because it will come at no cost besides, it is very popular on the marketplace.
Option 2
Planner by Tempo – Resource Planning & Capacity Planning
This plugin will cost 10$ per month. We are using it on the server version but i would recommend to check if the first plugin answer your needs and keep this option as the last resort.
Good luck and let me know how it went for you. Sharing your experience will also support other community members.
Karim
Karim ABO HASHISH
hi @vashim shekh
I updated the links, please check again and let me know if they are accessible now.
Karim
FREE
Register now
