Hey! Can I add second board in Kanban project ? https://i.imgur.com/8X34HSm.png
Вікторія Процюк October 5, 2022 edited
Trudy Claspill
October 5, 2022
If it is a Team Managed project you can create additional boards. However, you must create them based on a Saved Filter instead of based on the Project, and the board will not be listed in the navigation pane for the Team Managed project.
Refer to
https://community.atlassian.com/t5/Jira-Software-articles/Multiple-boards-in-Business-and-Team-Managed-Projects-You-bet/ba-p/1719761
Adam Wood
October 5, 2022
Hello!
This all depends on whether you are creating a team-managed or company-managed project. It's possible to create more than one board in a company-managed project but not in a team-managed project.
Team-managed projects are designed to be more straightforward with a single board, simple workflow and limited field options to be used in the issue detail view.
With a company-managed project, you'll be able to have multiple boards.
Boards are based on filters so it may be worth creating a filter first to use with the board you are about to create.
Creating a new board
  1. Browse to the project you want to create a new board for.
  2. Click the three dots in the top right-hand corner
  3. Select Create board
  4. Follow the steps, selecting your chosen filter for this board.
You can check the following documents for more information.
https://support.atlassian.com/jira-software-cloud/docs/configure-filters/
https://support.atlassian.com/jira-software-cloud/docs/what-is-a-jira-software-board/
Adam
Nic Brough -Adaptavist-
October 5, 2022
If it is a company-managed project, then yes, you can add multiple boards.
