Hide transition after 2 weeks for customer.
Eduard Diez
November 8, 2022
Hi community!
I would need to hide Transition after 2 weeks for client, but I don't have script runner and I don't know how to do it.
I have tried this way :
with string, with date (-2w), anyway from resolved field. And I got nothing.
Can you help me? thanks
3 votes
Alex Koxaras _Relational_
November 8, 2022
HI @Eduard Diez
You could achieve that with Jira Automation. What I'm thinking is:
  • Create a numeric field called e.g. CHECK
  • Place this field (if you want) on the view screen of your issue types
  • Have a condition inside your workflows and to that specific transition that the transition is visible only if CHECK is equal to zero or null
  • On jira automation create a rule to run each day and within this rule run an if statement e.g. if status = "waiting for customer" and updated <= -2w THEN edit the value of CHECK field to be something else besides 0/null
The above could work (in theory).
Try it out and let me know!
Eduard Diez
November 8, 2022
Wao! great idea, I didn't think in automation, is true.
I try and I answer you.
Thanks @Alex Koxaras _Relational_
November 8, 2022
Do let me know if that will work!
Like Eduard Diez likes this
Eduard Diez
November 21, 2022
@Alex Koxaras _Relational_  it works thanks!!!!
November 21, 2022
Good to know that!
