How I edit SLA Conditons
Peter August 18, 2020
Hİ,
I have a process like below;
Resolve SLA start, When I create a issue
Resolve SLA stop, When I change assignee.
Everything is OK until here.
Then I clone the issue, and assignee didn't change.
In this scenario, Resolve SLA never stopped.
How I write a condition for this problem? How I solve this;  when I clone issue, ı want to not stard resolve SLA if assignee is not empty.
Zoryana Bohutska _SaaSJet_
Hi @Peter
Try to set Start event as a first status issue gets once it created. (e.g To Do). Then, cloned issue will be moved to this status, the timer will start.  Or, try to edit your configurations for cloned issues.
Are you using JSD?
If you will need SLA timer for issues from Jira Software (as you mentioned in tags) you can try app like SLA Time and Report
Hope it helps
Regards
