How To Add a Watcher Based on the Particular Custom Field Drop Down Value in JIRA Cloud
Peddiboyina Nagendrababu December 2, 2018
We want to Add a Watcher Individually Based on the Particular Custom Field Drop Down Value  in JIRA Cloud...(WithOut Using Plugins and Scriptings)
Alexey Matveev
December 2, 2018
As @Nir Haimov said, you can not do it out of the box.
You could use the Power Scripts add-on:
https://marketplace.atlassian.com/apps/43318/power-scripts-jira-script-automation?hosting=cloud&tab=overview
You could write a listener for the Update Issue event with a code like this:
if (#{drop down field name} == "value1") {
  watchers = addElement(watchers, "user1");
Nir Haimov
You can't do that without plugin or coding.
This feature not exist out of the box in Jira.
You can use "Automation for Jira" (there is also "lite" version whic is free) and it's easy to use.
