How activate a template of checklist in automation ?
Xavier ESCANO
June 1, 2023
        I would like to activate a template of checklist with an event in the automation. Bu i don't have access to the chekclist in actions.
Best regards,
Xavier
Gracjan Wesołowski _HeroCoders_
June 1, 2023
Hi @Xavier ESCANO
Welcome to the community!
Do you use any of the checklist third-part apps?
If so, please let us know which app you are using, so we can give you the best approach.
Cheers!
Gracjan
Xavier ESCANO
June 1, 2023
Thanks for your contribution, I finally found a way to solve my problem here : https://herocoders.atlassian.net/wiki/spaces/CD/pages/3428550593/Apply+Checklist+Template.
Have a nice day,
Xavier
June 1, 2023
That's perfect! It is actually our plugin Issue Checklist for Jira :)
In case you will need any additional help related to the configuration, feel free to contact us via our help center.
Cheers!
Gracjan
Olha Yevdokymova_SaaSJet
June 1, 2023 edited
Hello, @Xavier ESCANO !
I would like to suggest using the Recurring Checklist and Reports add-on developed by my team, which may help with your needs. With this add-on, you can create checklists in two ways - the first is to create recurring task with a checklist inside, and the second way is to add a checklist to an already created task with one click.Untitled.png
With the ability to reporting in this add-on, you can also check report for the submission dates of all your employees and information from the checklist in one place.
Untitled.png I hope this helps and let me know if you need further assistance!
June 1, 2023
Hi @Olha Yevdokymova_SaaSJet
As a reminder...When recommending a marketplace vendor product, please ensure you disclose your affiliation to that vendor in your post wording. For more information about this, please see:
Atlassian Community online guidelines for Marketplace and Solution Partners
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Atlassian-Community-online-guidelines-for-Marketplace-and/ba-p/689723
Register now
