How add users group in form?
Jonathan Nuñez
December 6, 2022
Hi, I need to add a user selector based on a "Country" dropdownlist, ex if the country is Honduras then tag or assign user X , if the country is Argentina then tag or assign user Y and user Z.
Is there any way to do this in the epic form? I tried with dropdownlist, dependent dropdown, users but nothing.
Regards
Darryl Lee
Hi @Jonathan Nuñez --
If you want automatic assignment based on a custom field like Country, then you could use Jira Automation to create a rule that does this, although if you have a lot of Countries, this can be cumbersome.
Oh look! This exact rule is part of Atlassian's Automation Template Library:
If you have a lot of Countries or you'd like to delegate management of this assignment to non-administrators/Project Admins or you have more complex requirements, you might be interested in this article I wrote:
Lookup Mapping in Jira using Jira itself
Jonathan Nuñez
December 7, 2022
Hi @Darryl Lee
Thanks a lot for your reply!
I already solved with automation rules! :)
Register now
