×I have custom field which has double drop down as in
One drop down :
1. A
2. B
3. C
related drop down values depend on above values
if A is selected
1. D
2. E
if B is selected
1. F
2. G
etc
I want to use above field for Automation but unable to find this field. How can I add it ?
Hi Peyush,
welcome to Atlassian Community!
I assume you created a custom field of type "Cascading Select". Using witn Automation is possible, please have a look here.
There was also a dicussion on this topic in community in the past.
In case the custom field was created correctly it should be possible to find and access it.
Daniel
Thanks Daniel, I will go through this further.
I am still struggling on few more things such as :
1. How to find field name of custom field that I can use in smart values
2. How and where Can I use these values? Can I use these as trigger point
Is there any related video on how to use such fields?
Have you already had a look at the explanation for smart values?
To access an issue field, use the field’s name:
{{issue.My custom field name}}
. Field names are case insensitive and are translated using your rule actor's language setting.
It explains it pretty good. As for a video: yes, there is a Channel in YouTube for Automation of Jira (https://www.youtube.com/channel/UCTIvuZRaTXRcdMLAnyI82tg).
This video seems to handle the topic: https://www.youtube.com/watch?v=V4oKCRRvyRU
Daniel
Thanks Daniel, you have been of great help. This has resolved my problem.
