How can I automate a workflow step when bitbucket reviewer condition is met?
Elliot Jones
I have the following in place.
  • Developer places item from In Progress to In Review
    • PR is created ready for approvals
    • We set a minimum 2 approver restriction
    • Once this happens the PR is approved
Once this happens, I would like
  • the Jira issue to move from In Review to Ready for QA.
3 votes
October 6, 2023
Hi @Elliot Jones -- Welcome to the Atlassian Community!
Have you looked into using an Automation for Jira rule for this?  There are several PR-related triggers and one of them may be what you need to start the rule and transition the issue(s).
https://support.atlassian.com/cloud-automation/docs/jira-automation-triggers/#Pull-request-created
Elliot Jones
Thanks Bill will take a look!
Like Bill Sheboy likes this
Elliot Jones
It seems the guide here doesn't list my requirements :(
