How can I create a Dashboard Gadget to show #points per status? in a Pie Chart? Other?
Hello @Steve Hooczko,
I am Marlene from codefortynine.
By #points do you mean Story Points?
With our app Quick Filters for Jira Dashboards you can sum up any number field with the statistics and pie chart gadget. In the screenshot you can see the "Quick Issue Statistics" and the "Quick Pie Chart" gadgets as examples.
I do not believe that is possible with the built-in dashboard gadgets. Perhaps look at the Jira Marketplace for some gadgets to help.
And if you do not need this often, you may want to export the issues and do this in a spreadsheet for other reporting/charting.
I've been using the Excel approach until now. Was wondering if there was something in JIRA I may have missed.
Thanks for your suggestions.
