How can I create multiple issue layouts in the same project?
Eduardo Tavarez March 25, 2022 edited
I have a company managed business project. I successfully customized the layout for 1 issue type. The thing is that I will like other issue types to exist in the boards, but when I add them, all issue types follow the same issue layout.
I tried creating a new issue type scheme and associating the project to it as well but I am getting the following error:
You can't associate independently-created projects with this issue type scheme.
  • There are 58 sub-tasks that will be affected by this change. You must have at least one valid sub-task issue type.
4 votes
Ste Wright
Hi @Eduardo Tavarez
When you say Issue layout, I assume you mean the order of the fields on the screen?
I.E via Project Settings > Layout?
To allow for this, you need a Screen Scheme per Issue Type.
To set this up, you'll need to be a Jira Admin and then...
  1. Go to Jira Settings (cog icon in top-right) > Issues
  2. Select Screens from the left-hand menu
  3. Locate your Screen, and on that row select 3-dots icon > Copy
  4. Give the new Screen a name, for example Screen - Bugs
  5. You can modify the fields available on the Screen if needed - or leave it exactly the same!
  6. Repeat steps 3-5 for each Issue Type's layout you want to modify
  7. Next, select Screen Schemes from the left-hand menu
  8. Press Add screen scheme - and create one Scheme per Screen (i.e if you have 5 Screens, you need 5 Screen Schemes)
  9. Finally, select Issue Type Screen Schemes from the left-hand menu
  10. Locate the Issue Type Screen Scheme for your Project
  11. Use the Associate an issue type with a screen scheme button to associate each Screen to its Issue Type
It should then be possible to set an Issue Layout per Issue Type!
Note: This will impact all Projects using the Screens/Schemes - if this is an issue, copy Screens for all Issue Types, and create new Screen Schemes/Issue Type Screen Scheme.
See more information in the Support help pages for...
Let us know if this works, or if you have any further questions!
Ste
Ste Wright
Hi @Eduardo Tavarez
For the edit you've provided...
If you're looking to modify the Issue Type Scheme, and have Sub-tasks now, you need to either...
  • Convert all Sub-tasks to a standard Issue Type
  • Add at least one Sub-task Issue Type into your Scheme
...for the Issue Type Scheme association to work.
Ste
Hi @Ste Wright
I did as you suggested and added a sub-task issue type to the scheme and it allowed me associate. However this made the project to stop being associate to the previous scheme. I am attaching an image to try and make this clearer. In the project Services 2.0 I have an issue type with its own layout and that is great. I will also want this same project to have the General Issue type but with a different layout, but in the same project. How can I accomplish this?
Ste Wright
Hi @Eduardo Tavarez
If you mean Issue Layout as in what fields are on the Screen, their order, etc - see my first post.
If you need to add the General Issue Type to your other Scheme also...
  1. Go to Jira Settings > Issues
  2. From the left-hand menu, select Issue Type Schemes
  3. Locate the Issue Type Scheme - eg. SS2: Services issue type scheme
  4. On that row, select 3-dots icon > Edit
  5. Move General from the Available Issue Types column, into Issue Types for Current Scheme
  6. Press Save
Do this before adding more Screens/Schemes.
Ste
Thanks again @Ste Wright I really appreciate it.
Like • Ste Wright likes this
Help us plant more trees
