How can I delete an issue in Jira Cloud(I am the project lead)
Carol Rodriguez
Hi all,
Does somebody could tell me how can I eliminate a task created in jira cloud?
I am the owner of the project but I can not find the option to delete the task. I share a screenshot so that you can help where should I click on.
Thanks in advance!
2 accepted
Alexander Bondarev
April 29, 2021
Hi, @Carol Rodriguez !
First of all you should check your project permission on "Delete issue" permission.
Documentation - Manage project permissions .
Then you can delete an issue like @Tibor Tasi _Everit_ told.
Carol Rodriguez
Hello Alexander thank you very much!
Like Alexander Bondarev likes this
Alexander Bondarev
April 29, 2021
Did you manage to delete the issue?
Tibor Tasi _Everit_
At the top right corner there is a ... menu where you can find the delete button:
Carol Rodriguez
Hello Tibor thank you very much!
Like Tibor Tasi _Everit_ likes this
John Funk
Hi Carol,
First, it's rarely a good idea to delete issues in Jira. It is better to move them to another status such as Discarded or Aborted or Abandoned or something like that. Otherwise, something will inevitably get deleted that shouldn't be.
But if you must, you will need Delete Issue permissions in the Permission Scheme for that project.
