Sign up Log in
How can I fill a customfield with a CSV file?
Eduard Diez
December 22, 2022
Hi community.
I mean, users have an employee number, and now they want to use a CSV or EXCEL file to fill in all the issues of a project. for example
 User Number
 Pako Pil 254455
 Aitor Tilla 544454
And I don't know how to do it, can you help me?
P.S.-> I don't have script runner, that makes things more complicated.
3 accepted
Alex Koxaras _Relational_
December 23, 2022
Hi @Eduard Diez
Take a look at this documentation https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
The most important thing is to include the issue key in order to update the proper issue.
December 23, 2022
@Eduard Diez to answer your question:
Hi again.
What I need is to put the data of an employee number in all the issues of a project, all employees have a company identifier and have several issues assigned, so I need a CSV that I pass to put in all the issues.
I know that if I download by a jql all the issues of a project and I add the identifier by hand, and then I import it, it can be done, but I want to know if there is another simpler way.
No there isn't a simpler way for what you want to achieve. If you want to import different employee numbers to different issues, then this is the way to go.
If you want to import the same number to different issues, then this could be achieved by bulk edit. But that's not your case.
Like Eduard Diez likes this
Eduard Diez
December 23, 2022
Hi @Alex Koxaras _Relational_
that's fine and I understand what you are telling me, just like importing the issues and putting the number of employees, but let's assume there are 500 employee, how can I make the new isses without script runner, because with script runner I can think of a lot of ways.
Thanks to all of you
December 24, 2022
@Eduard Diez I'm confused as to what your business requirement is. Can you please describe it in a sentece? E.g. "I want to create new issues on a specific jira project and these issues must be populated with certain fields. In addition I want for each of these issue a specific field to have a different value".
Eduard Diez
December 23, 2022
Hi again.
Thanks to all
@RISHAV KUMAR GUPTA , @Alex Koxaras _Relational_
RISHAV KUMAR GUPTA
December 23, 2022
Hi @Eduard Diez ,
As they contains different values for user and Number The better option would be the Bulk import as I have mentioned in excel sheet.
Rishav
RISHAV KUMAR GUPTA
December 23, 2022
Hi @Eduard Diez ,
Here you go , I have attached a sample format from where you can import via CSV.
ATL comm1.png >
Rishav
Eduard Diez
February 13, 2023
Thank's
Register Now
Upcoming Jira Events
