×Hello there, I'm working on projects with different people and i don't want them to see each others work (which is described in the issues).
Can someone tell me how to make issues "invisible" for some people, or exclude them from certain issues?
Thank you!
Ho @Maya Stoll
welcome to the Atlassian Community.
There is a feature for exactly this use case called „Issue security“
see the following link:
https://support.atlassian.com/jira-cloud-administration/docs/configure-issue-security-schemes/
Best
Stefan
Hello Stefan, thank you for your answer!
If I'm seeing it right, I can't do this in the free plan?
Best wishes
Maya
Ah….yeah that‘s correct :-/ unfortunately that‘s not available in free plan
Okay, too bad.
But thank you for your help anyway! At least I know now :-)
Dear @Stefan Salzl ,
i haven't free plan, but i can't found this project settings in workmanagement anywhere.
Do you can help me in this case, how can i set up this for the projects? I setted up the permissions in the global settings.
regards
Jozsef
are you using company managed or team managed project?
what do you mean you set up permissions in global settings?
Please send some more details as well as screenshots.
Best
Stefsn
did you follow the link from my initial answer?
It describes all the steps. it´s not only to set the permissions but furthermore to create an issue security scheme which consists of security levels.
This configuration then specifies who is allowed to see certain issues (according to level) and who not.
Best
Stefan
