How can I make the list of issues public?
Martin Brampton
December 13, 2021
I've created an account, upgraded to a trial standard plan, created a project, and one issue for that project.
I want to be able to show the list of issues for the project to the  public, but don't know how to do it. Can it be done?
Howard Nedd
December 13, 2021
Hi Martin,
I believe you can accomplish this the following steps:
  • Choose Settings.
  • Choose Issues > Permission schemes.
  • Click permissions for the permission scheme of the project that you want to enable or disable anonymous access for.
Anonymous access to view and search for issues in a project
To allow users to view and search for issues in a project without logging in, add the Anyone group to the Browse Project permission in the permission scheme for the project.
To make sure anonymous users can't view issues in a project, verify that the Browse Project permission is only granted to existing project roles, groups, users, or Any logged-in user.
I hope this helps.
Regards
Howard
Martin Brampton
December 13, 2021
Thanks, Howard, I was able to follow that and it seemed to make sense. But unfortunately didn't give the desired result. The setup after the change showed:
But going to a different browser and attempting to look at projects gave the answer "You can't access any projects or issues". Waiting a few hours didn't make any difference. This is the result:
Did I do something wrong?
Learn more
