×Hi there, How can I move a task from bottom of a timeline activity list to mid way existing activity list.
For example, I created a timeline with Plan; Requirements, Design, Build, Test and Deploy phases. Next, I added in a QA Test phase and realize it is not in the proper order. It appears after Deploy section but I want it to appear after Test section. Is there a way to move the QA Test section to fall under the Test phase section?
Hi @Josette C welcome to the Atlassian Community!
It seems to me you are talking about the workflow statuses as a timeline.
On a scrum or kanban board, you can move add/move/delete columns and then drag and drop the statuses to the desired 'order'.
Have a look at the following documentation page: Configure columns
