How can I rename a closed sprint?
Danny Gershman June 19, 2013
I have a Sprint that is closed that I want to rename. We have changed our Sprint naming conventions and I want to be able to rename the older ones.
Timothy
June 19, 2013
The only way would be to change the name in the database. You should be able to find the table "ao_xxxxxx_sprint".
I'm using OnDemand. How can I change tables?
Timothy
June 20, 2013
Too bad then. No workaround for you unless support changes it for you.
Learn more
