How can I reopen closed sprint?
Noura Alotaibi
November 28, 2021
I closed the first sprint by mistake, and I need to reopen it to complete the needed.
Walter Buggenhout
Hi @Noura Alotaibi and welcome to the Community!
In short, these are the steps you can take to reopen a sprint:
  1. Choose Projects and select a project, or choose View all projects to visit the projects directory.
  2. Select the relevant project.
  3. Click Reports, then select:
    1. Sprint Report if you are in a company-managed project.
    2. Burnup report or Sprint burndown chart if you are in a team-managed project.
  4. Select the relevant sprint from the sprint drop-down.
  5. Select more > Reopen sprint. The Reopen Sprint dialog will be displayed, showing you the outcome you can expect when the sprint is reopened
  6. Click Reopen.
It may be worth reading this support article before you do so to consider potential implications first.
Hope this helps!
Learn more
