How can I reset the worklog via an Automation?
Dominique
I want to reset the worklog to "0" in certain situations but am unable to find out how to do it.
Untill now I was able to add a certain amount of time, by the following:
  "update": {
    "worklog" : [
        "add": {
          "timeSpent" : "6m"
but when I replace "add" by "set" and 6m by 0m it does not work.
Anyone out there how knows how to do it?
Thx in advance!
Mélanie Liguet
Hi @Dominique Hermens ,
Do you resolved it ?
I have the same issue.
i need to remplace a worklog with a new value.
I can only add a new worklog , i can't edit or set it.
regards,
Dominique
@Mélanie Liguet not yet unfortunatelly.
September 21, 2022
Hi!
I have not tried this, and I believe you can do this by repeatedly calling the REST API with a web request to delete each entry, in an advanced branch, as Rilwan described below.
Here is an updated reference to the method and a how-to article for calling an API from a rule:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-worklogs/#api-rest-api-3-issue-issueidorkey-worklog-id-delete
https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
