How can I search Jira/JQL for code snippets?
Ryan Hagan
February 14, 2022
Is there a way I can search Jira for code snippets? I'm collecting snippets that can serve as samples.
I'm using this JQL query - is there a way to target code? Or search for braces/brackets?
project IN ('Inbox') AND (text ~ "sample" AND text ~ "example" OR text ~ "code" OR text ~ "snippet") AND created >= startOfYear(-1) and created <= endOfYear()
Aron Gombas _Midori_
You cannot search code with JQL.
JQL can only return issues, nothing else.
If you store your code in Bitbucket Cloud, you can use its own search feature for that purpose.
Trudy Claspill
Hello @Ryan Hagan
Welcome to the community.
There are a few open issues with native text searching in Jira Cloud that will impact your ability to find a solution. Refer to
https://jira.atlassian.com/browse/JRACLOUD-75866 - problem searching for special characters
https://jira.atlassian.com/browse/JRACLOUD-21372 - problem searching for exact phrase
https://jira.atlassian.com/browse/JRACLOUD-69263 - problem searching for exact text
You'll also want to refer to these documents:
https://support.atlassian.com/jira-software-cloud/docs/advanced-search-reference-jql-operators/#Advancedsearchingoperatorsreference-CONTAINS-CONTAINS--
https://support.atlassian.com/jira-software-cloud/docs/search-syntax-for-text-fields/
Get Certified! ✍️
