How can I select multiple issues from backlog and add them to a certain epic
Sama Mohamed
If anyone can elaborate with pictures I will appreciate that
2 accepted
Fabio Racobaldo _Herzum_
Hi @Sama Mohamed ,
you can do that just selecting multiple issues from the backlog and associate them to an existing epic
Number on the right of your selection will say you the number of selected issues.
Hope this helps,
Fabio
Sama Mohamed
@Fabio Racobaldo _Herzum_ Thank you so much, this illustration helped alot.
Thuan_ Do Dang
July 29, 2022
Hi @Sama Mohamed ,
You can do it by 2 way
  • Filter your issue -> bulk change -> update Epic Link
  • In your board backlog, expand Epic panel then use Ctrl or Shift + Click (in window) or Command or Shift + Click (in Mac) to select multiple issue. After that, drag and drop them to the right Epic card in Epic panel. Wait for a few seconds if you're using Jira cloud then refresh the page to see the update.
Sama Mohamed
@Thuan_ Do Dang Thank you so much for help
Register here ⬇️
