Hallo,
is there a possibility to have advanced roadmaps only for some users, because we need this feature only and we need to move the whole plan to premium and this will cost my organisation a lot. I am trying to find some solution here where we would use advanced roadmaps but not move the whole organisation to premium.
Thank you
Hi Adam,
This is not possible. ARJ is a premium feature only accessible for teams/organizations on the premium or enterprise plan.
- Hamza
Hi Adam,
another option might be to look for alternatives in the Atlassian Marketplace. Depending on what exact capabilities you need, you might find apps that are significantly cheaper than Premium, or potentially even free.
If you share your requirements, I'm sure a lot of peeps will be happy to share their recommendations :)
Best,
Hannes
Thanks Hannes,
we basically need cross-project roadmaps for management. That is it, if there would be a recommendation I will be happy to hear it and try alternatives to premium.
Best, Adam
