×Hi everyone!
I'm quite comfortable with JIRA... except JQL queries!!!!
So I want to create a filter that captures all tests in a project WITHOUT a label! I'm inputting syntax which to me makes sense, but alas with most of my queries JIRA says no Could anyone help me input the right syntax? This is what I've input:
image2016-2-11 11:8:57.png
Thanks in advance everyone!
Brett
Thanks for the answers!
@Steven Behnke I tried that with the same result.
@Rahul Aich @Rahul Aich [Nagra] I will try that thanks! Though I will be back to my original issue if we attach any labels on them haha
Any other comments from people will be most welcome! Thanks
Can you clarify, you want to find issues with no label, or issues without a specific label.
I want to run a query that strips out a label... so I want it to return all tests that do not have a specified label
have you tried
labels != YourLabel or labels is empty
put this in brackets if you have additional conditions in your filter
Hm, shouldnt you use != instead of is not?
is and is not are for checking for empty valuea, ie labels is not empty.
Have you tried the syntax
labels is null
Rahul
