How can I transfer a part of the ticket description into a field?
cDemmerle December 17, 2022
Hi!
In the ticket description we always start with an order number followed by customer and then what it is about.
I am looking for a way to automatically copy the first part of the description, which is a pure number sequence like 2022100-007 into the ticket field "Project number" to not have to do it by hand. Is that possible via an automation rule with field customization?
image.pngThanks in advance for your support!
Greetings CD
Alex Koxaras -Relational-
Hi @cDemmerle
You can create an automation rule using smart values for text field, in order to get the first part
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
Then copy that part on to the field you want.
Hi @Alex Koxaras -Relational- ,
thx! That works! I used this value and the first Tests were good.
Have a nice week and great Christmas!
Well done @cDemmerle for pulling that out! Great job!
FREE
