How can I use two different Field Types in one custom field?
Example:
_Checkbox 1
_Checkbox 2
_Checkbox 3
Other: (ability to add text)
Thank you!
Nope. You have to select the type when you create the field. 1 Type per field.
You can have different values (contexts) for different issue types and projects, but not actual different field types.
Hi @Julie Sgroi
You can't. The solution you are looking for is a plugin such as dynamic fields from deviniti where if "other" is selected, a new field with text displays below it.
Cheers
