How can I visualise all projects on one timeline
danny austin
September 4, 2023
Is it possible to view all of my teams projects (down to the mega level) on one timeline? the single project overview timeline is excellent but I want to be able to see all running projects at once.
Irina Cherkasova - Planyway
Hi @danny austin
It's Irina from Planyway:)
You can try out Planyway plug-in for Jira to visialise tasks from multiple projects on the same Timeline.
There is even more to it as you will be able to create a portfolio view of all your current projects by applying the project filter to the original view.
danny austin
September 6, 2023 edited
Magic! Thank you for taking the time to take screen shots and explain this. Much appreciated
Trudy Claspill
Hello @danny austin
With the Free and Standard plans there is no native way to display multiple projects in a single timeline. You would need to add a third party app such as was suggested by @Irina Cherkasova - Planyway
There are several such apps available from the Atlassian Marketplace.
Here is an example search:
https://marketplace.atlassian.com/search?hosting=cloud&product=jira&query=project%20management
You might also search for "portfolio management" to get a slightly different list.
Jon T
January 14, 2025
@Trudy Claspill You said there was no native way to display multiple projects in a single timeline using the free or standard plans.
Does the premium or enterprise option offer a native way to do this?
Trudy Claspill
@Jon T
Yes, those subscription plans offer the Advanced Roadmaps features which support showing information from multiple projects in one Timeline.
https://www.atlassian.com/software/jira/guides/advanced-roadmaps/overview#what-is-advanced-planning
https://support.atlassian.com/jira-software-cloud/docs/plan-and-view-cross-project-work-with-advanced-roadmaps/
Jon T
January 14, 2025
Thank you @Trudy Claspill for answering my question that I posted on an older post.
I will look into those links.
I am new to these community boards. How can I reward you for answering my question in a manner I found helpful?
Does me liking your answer to my question benefit you? Or do I need to upvote your reply to the original question to have a benefit to your account?
Trudy Claspill
I'm glad you found my answer helpful.
Likes are always nice.
You can also hover over a user's name and click the Give Kudos button.
You can give kudos 10 times each week.
When you post a new question and you get an answer that is helpful, there will be a button labeled Accept Answer above the response thread. You can click that button to indicate the answer was helpful, but only when you are the author of the original Question. Accepting an answer gives kudos to the person who provided the answer.
Here are some additional resources to help you get started in the community.
Community FAQ
Community Guidelines
Welcome to the Community Kudos program
Like • Jon T likes this
FREE
