Every time i create an Epic, i want to create all this sub itens above, how can i automate this?
Because all my epics at this project have the same structure, and i dont want to create one by one everytime an epic is created.
You can use automation to generate those issues for you every time you create a new epic in the project. I would take a look at the Jira automation template library to see how you can use automation.
yes i know the automation, i have tried but i can not find the way to make all this Childs..
this one you sent, is not for that, is for youtube videos..
YouTube videos is just the Issue type. It can be Sub-task or Story or whatever you want it to be.
Have you created a rule? Can you share that?
I can not change to english, dont know if you will understand.
I add an epic, but the Sub issues i want to create as childs of the epic, they do not create as Childs..
You don't need the branch, just take that out.
But when you create the child, be sure to update the Epic Link as a part of the create. Use the value of Current Issue in the drop down.
now i get it!
but for the task i want them to be a child of the story before;
and also want to add subtasks to the task issue, but is creating in the subtasks at the epic and not at the task, can you help me to do it?
Learn more
