How could I create project without using template?
Whenever I want to create project it gives me only option with creating it using
template.
Hello @ROIKA
Welcome to the community!!
Currently, there is no option to create a project without the template. The templates are provided/ enabled as guidelines with a basic set-up. This can be customised as per your business use case like adding a new issue type, editing the screens, adding custom fields etc.
Let me know if you need help with such customizations.
Kindly accept the answers if this helps you.
Help us plant more trees
