×I'm running into an issue trying to access Custom Variables created in Automation while iterating through a Smart Value List.
An simplified example:
There are two Custom Variables defined in the Automation Workflow:
{{MyList}} = "a,b,c,d,e,f,"
{{MyVar}} = "A"
I can use a Log Action with following, and it will return "abcdef & A":
{{#MyList.split(",")}}{{.}}{{/}} & {{MyVar}}
But when I use a Log Action while iterating through the first Custom Variable, and try to reference the second Custom Variable from within, it fails.
In this example, the following returns the string "abcdef" instead of "aAbAcAdAeAfA".
{{#MyList.split(",")}}{.}{{MyVar}}{{/}}
How do I reference a Custom Variable while iterating through a Smart Value list?
