Within my 'To Do' column I have multiple story cards.
The default has 'Title', 'Story Id' and 'Assignee'.
I need to add my custom field 'Hours Est.' to this card.
How do I do this? (I am an administrator)
Hi @Darren Conroy ,
welcome to the Atlassian Community!
You can configure cards on a board to display up to three additional fields. The fields can be different for the Backlog and Active sprints, if you are using a Scrum board.
To add fields to cards:
If not already there, navigate to your company-managed project.
Select Active sprints (if you use a Scrum board) or Kanban board (if you use a Kanban board).
Select More () > Board settings.
Select Card layout.
Add or delete fields as desired.
Hope this helps,
Fabio
Note (as stated at the top of the help link) that this applies to company-managed projects only.
Team-managed projects cannot do this useful thing, I have just recreated my project to be able to add fields to cards.
Learn more
