How do I add a custom field to my roadmap?
kateu April 26, 2021
In the basic roadmap feature, there doesn't seem to be a way to configure additional fields to filter by.  I have a field "customers" in all my user stories, and I want to be able to filter by customers or at least visualize this field on the roadmap. Is there way - perhaps not in basic but in advanced? Tx!
Trudy Claspill
That doesn't appear to be an option for Basic Roadmaps.
If you identified the customer for each issue using the Labels field instead of a Custom Field, then it appears you would be able to use the Labels filter option in Basic Roadmaps. If you want to retain your Custom Field, you could perhaps additionally identify the Customer through the Labels field.
It appears that with Advanced Roadmaps you can construct additional filters that you can use with your roadmap, as mentioned in this guide.
https://www.atlassian.com/software/jira/guides/roadmaps/advanced-roadmaps
Register today
