How do I allow the default assignee to be 'unassigned' at a project level
Paul Treadwell
In Jira cloud we currently have 'allow unassigned issues' =OFF.
So each Project (in project settings) has a project lead set.
I want to allow one particular project to allow unassigned issues (in fact I want the default to be 'unassigned'). So do I change the global setting to 'allow unassigned issues'. Then go to my project in question and change the project lead to be 'unassigned'?
My concern is... will this impact any other project we have? Apart from the fact that someone could change an issue to 'unassigned' at some point (even though the default will remain as per their 'project lead' setting). I can cope with that outcome. I just don't want to somehow wipe all the other project 'project lead' settings.
Tansu Akdeniz
June 30, 2021
Hi @Paul Treadwell
In order to allow unassigned issue in a particular project, you need to turn the global setting ON.
It will not change current project settings. Proje leads will stay same and default assignee will be "project lead" again. But you will have a change to change project lead to unassigned. So, you can do it safely.
Paul Treadwell
Fantastic, thanks so much for answering. That was how I assumed it worked but wanted someone to get an expert opinion on it.
Tansu Akdeniz
July 1, 2021
You are welcome !!
Bogdan Shkoda
July 6, 2021
Thank you Tansu
