Hi all!
I'm trying to link an specific screen schema just for Epics. Currently all the issue types in the project (except bugs) use a default schema.
Everything I've tryed so far looks like I'm changing the schema but I just want to add an schema and link for epics onle.
Thanks in advance
You must include the schema for epics in the issue type screen scheme that applies to your project (note that this will apply to all projects that use this scheme), for example, my issue type screen scheme is "TEST: Kanban Issue Type Screen Scheme" You must perform the following actions:
I hope it will help you
Regards
YES!!
Thanks a lot!
I was trying this for days now. Now it's working.
I'm glad it's working now!!!
If my answer helped you, could you please accept the solution?
Thank you very much and best regards!
Hello @Fabian Jimenez
Welcome to the community.
Please first confirm that you are working with a Company Managed project and not a Team Managed project.
For a Company Managed project, your project with have an Issue Type Screen Scheme associated to it.
That contains Screen Scheme(s) that are associated to issue types.
You have to modify the Issue Type Screen Scheme to include the new Screen Scheme and associate it to the Epic issue type. Note that will affect all projects that use that Issue Type Screen Scheme.
Register now
