I've created a Technical Writing Kanban Board, with a requirement to add an automation - Technical Writers require notification via Slack and MatterMost (realise that I need the MM api and MM Git access) when a reviewer has checked the "Reviewed by" check box.
While I've set up some automations for alerting via Slack, I have not managed to discover how to set this request up in a simple way - by the automation triggering when the checkbox is checked by a reviewer - using the drop-down function.
Any input and help much appreciated. Thanks!
Hi @David Witcomb -- Welcome to the Atlassian Community!
I recommend breaking your use case down into pieces, build it up, and that will help determine if this is possible. For example:
If you can detect the field change in the rule, you should be able to create a rule, perhaps like this:
Hey @Bill Sheboy Thanks for your quick response.
Will attempt to create the rule with your tips. Thanks for your input.
David.
Sounds good, David. If you have issues creating your rule, please post the rule and audit log images so the community can help. Thanks!
So far so good. Rule created and webhook works for Slack.
Now to apply the Rest API for MatterMost :)
Help us plant more trees
