I have an 18 step custom workflow that took a ton of time to refine and automate. That said, I am looking into a way to change the two locked status next to the workflow dropdown. I have many of the status' allowing 'ALL' to transition to it, but it seems the 2nd locked status is arbitrary and I can't figure out how to lock "Blocked" instead of "awaiting feedback" next to the workflow dropdown.
See screenshot:
You can re-order them in the JIRA (server) using the ops.bar.group.size.opsbar-transitions, not sure with Cloud. https://confluence.atlassian.com/jira/configuring-workflow-185729632.html#ConfiguringWorkflow-Customisingworkflowtransitionsonthe%27viewissue%27page
Works on Cloud too, so that's the right answer completely (unless the questioner means something different by "locked")
