How do I configure private, per-vendor projects?
eacwpku January 25, 2016
We're evaluating JIRA cloud and I have some questions about setting up a specific type of project and permission scheme. We are a application/services shop and will have several projects that all of our teams can collaborate openly on.
However, we also need to setup a project-per-vendor where we can invite limited persons from our various vendors to open issues or respond to our questions. I don't want them to see any of our internal projects or other vendors' projects.
I'm worried that the permissions scheme to maintain this kind of setup will become a nightmare... am I right?
We'd have to maintain an internal-users group, a group-per-vendor, and assign permissions/schemes to view projects like:
  • vendor bar project: internal-users, vendor-foo
  • vendor bar project: internal-users, vendor-bar
  • internal project qux: internal-users
James Strangeway
January 25, 2016
Hi Anthony,
We do this exact thing.  I agree with Phil, if you need really customize what level of permissions you are going to give each vendor, then a role is the best way to do this.  We use a deafult permission scheme, with the default project roles.  We then create groups for each of the project developer and stakeholder groups and assign them the appropriate project role.  I strongly agree with Phil on making sure there are no group or individual permissions assigned in your permission schemes.
Phill Fox
Hi @Anthony Mastrean
You will be pleased to hear that the permissions will not be a nightmare if you configure it right.
JIRA comes with the concept of user roles on a project. So here is a set of steps for you to work through to make it easy to manage.
  1. Add a new role to JIRA "vendor"
  2. Define your shared permissions scheme using is in project role "Vendor" to determine what they can do. Eg Browse/create/edit/add comments etc.
  3. Ensure you also set the appropriate permissions for your internal staff.
  4. Apply your shared permission scheme to each vendor project.
  5. Manage the members of each role for a project to allow them to have access and only access to the right projects.
Couple of things to check
  1. What is the permission scheme in place for other projects? Make sure this does not include any groups that would allow everyone such as jira-users to see a project.
  2. Make sure that at least the project lead has administer project permission to be able to add people to the different roles.
This sounds about right, but requires constant maintenance. Every new internal team member has to be explicitly assigned to the correct group and every new project has to be assigned the correct scheme.
I was hoping there was an explicit feature for privatizing a project or limiting a user's view that required explicit action only on those projects/users.
James Strangeway
January 25, 2016
Right.  It can require some overhead.  Like each project does require us to create a new group for stakeholders, but we have one dev group for the majority of our projects, which we just have to assign to the developer role.  Does not typically require us to move people in and out of the dev. group.
Phill Fox
The management of the approach I suggested is relatively simple (and with the right permissions) is delegated from the system administrator to the project administrator. The only action once it is setup is to add/remove users from the role on the project.
Learn more
