How do I create a table in description section using rest API in javascript ?
Rahim T_S
January 30, 2023 edited
I'm using https://www.npmjs.com/package/jira-client wrapper class to create a Jira automation utility and one of the requirements is to read data from excel sheet and upload the relevant data as a table to the description section of the created issue
This wrapper class seems to allow only string type as acceptable value. I was able to parse a simple html table as a string and create a table but when it comes to big tables how can I handle those ?
Can I use the custom fields option to do this ?
From the API documentation it seems that the description field can be modified to send tables, can someone help me figure out how ?
3 votes
Fabio Racobaldo _Herzum_
Hi @Rahim T_S ,
tables in description is part of the text. You could try to add the following :
||Heading||
|Your cell value|
Please let me know if it works,
Fabio
Rahim T_S
Hi @Fabio Racobaldo _Herzum_ that seems to work. Thank you
I added as
description: "|Name||Rahim|" and I got the result reflected in the issue.
But how can I create rows and columns ?
I tried like
description: "||Name||||Title|||Rahim||Software Engineer|"
but got all as values of a row
| column 1 | column 2 |
in order to create a new row you just need to add carriage return in your text.
Like Rahim T_S likes this
Rahim T_S
@Fabio Racobaldo _Herzum_ That worked. Thank you so much for your help
you're welcome @Rahim T_S  ;)
akshatjain057
March 20, 2023
does it actually renders as the table ? it comes as text only for me , how to add carriage return in text on mac ?
Tyler Do March 22, 2023
I tried
description: `||Test1|| |Test2|`
But i just get exactly text in my description, there's no actual table in my ticket, can you help, appreciate
 @Tyler Do , please check the renderer associated to description field in the field configuration
Tyler Do March 23, 2023
@Fabio Racobaldo _Herzum_  I don't actually get what you mean but I'm using jira.js and try to create a ticket like this
client = new Version3Client({
    host: process.env.JIRA_HOST,
    authentication: {
      basic: {
        username: process.env.JIRA_USERNAME,
        password: process.env.JIRA_PASSWORD,
const issue = await this.client.issues.createIssue({
        fields: {
          summary: fields.summary,
          description: "||Name||||Title|||Tyler||Software Engineer|"
          project: {
            key: fields.projectKey,
          issuetype: {
          assignee: {
And there are no table is rendered
it work when I tried like
description: {
"type": "doc",
"version": 1, "
"content" :
"type": "table",
"content" : // content goes here
But it take too much configuration, though your way will be more easier but it didn't work
Field configuration and renderers are at configuration level and not at request level. https://support.atlassian.com/jira-cloud-administration/docs/configure-renderers/
Tyler Do March 27, 2023
@Fabio Racobaldo _Herzum_  sorry for late response, so I can't add something like
in my description by request to this api POST /rest/api/3/issue right ? in order to render a table.
If so, where exactly do I need to put/insert them so that I can render a table using your way? I've read the document above but not fully understand it.
Appreciate your help.
Hi @Tyler Do ,
probably you need to encode your description before using REST API. (https://www.urlencoder.org/)
Tyler Do April 11, 2023
@Fabio Racobaldo _Herzum_, sorry, just came back after the holiday, but it still doesn't work, appreciate any help from you, thanks.
Rahim T_S
Will this be helpful for you ?  html-tablify. This worked for me
Rahim T_S
@Tyler Do I moved on to using html-tablify This works
Register here ⬇️
