I am looking at how to create an automation for already Canceled parent tickets.
I want to take the currently Canceled parent tickets and get all the subtasks to be set into a "Review Unnecessary" status.
Project = Launch Tracker
Parent Issue Type = Feature Launch Tracker
Subtask issue type = 'sub-task' + 'Eng Launch sub-task' + 'Quality Eng Testing'
Hello @tbundy
Have you tried to construct this automation rule? What do you have so far?
You could use a Schedule trigger with a JQL statement to select all the Feature Launch Tracker type issues that are in the Canceled status.
You could then add a For Each: Related Issues: Sub-tasks step to select all the sub-tasks of each issue retrieved by the trigger.
Within the For Each branch you would then add a Transition Issue action to change the sub-task issue status to "Review Unnecessary".
Note that each sub-tasks needs to be in a status currently where the transition to "Review Unnecessary" is valid. If there are statuses where that transition would not be valid, then you may want to add a Condition inside the For Each to check the status of the sub-tasks, and then execute the transition only if it would be valid.
TRIGGER: Schedule
JQL: project="Launch Tracker" and issuetype="Feature Launch Tracker" and status=Canceled
FOR EACH: Sub-task
CONDITION: Issue Field Condition
Field: Issue Type
Condition: is one of
Value: (the values from which a transition to "Review Unnecessary" would be valid)
ACTION: Transition Issue
Destination Status: Review Unnecessary
Register now
