How do I delete an epic?
Brian Maloney
May 13, 2013
I created an epic when I should have created a sprint.
8 votes
Henning Tietgens
May 13, 2013
An epic is a normal issue. You could open the issue and delete it (More Actions -> Delete).
Henning
Brian Maloney
May 13, 2013
Thanks for the quick reply Henning. Turns out I didn't have access rights -- do now and see the delete option you mention.
Sam Finding
December 4, 2014
Thanks Henning - turns out I needed access rights as well.
matt chung
September 22, 2015
where are these access rights set?
Amos VanHorn
October 27, 2016
Project Settings --> Permissions --> Actions Menu (upper right) --> Edit Permissions
Then click the upper-right "Grant Permission" button.  Choose "show more", select "Single User" and find your username in the user text box above.
Like • 2 people like this
bgbruno
July 13, 2017
Hello @Amos VanHorn, thank you for steps, but I don't see what next.
Q can you help?
Henning Tietgens
July 17, 2017
To delete issues you need the Delete Issues permission. Select it and add it to your group or project role.
Mark Skidmore
I created an issue, assigned an unwanted Epic to it, deleted the issue, but the Epic still remains. (Still) missing on how to delete an Epic. Thanks.
Mark Skidmore
I found it. On the Backlog page with VERSIONS and EPICS displayed, on the EPICS frame, the list of epics is displayed. It's here that you click the drop arrow to the right of the epic name, click "View epic details" and when the new page displays, in the upper-right corner, click on the ellipses then click Delete...
Hasmik November 20, 2018
@Amos VanHorn can I give a epic delete permission to myself or admin should do that?
Jaylah Cranmo
January 25, 2021
so i need help deleting a search on epic
Anatoly Spektor
It is def not as easy as I thought.
You need to first use search to find ,it then you need to make sure you have the right permissions (I mean admin permissions). If you are a more visual person, I created a video .
