How do I delete storage?
Sati Hillyer
October 15, 2025
I'm trying to delete old storage to free up space, but I don't see a delete option. I'm the jira admin.
Any ideas?
John Funk
Hi Sati - Welcome to the Atlassian Community!
Basically what is taking up your storage are attachments on Work Items. Delete some of the bigger attachments and you should be good.
Sati Hillyer
October 15, 2025
Hi John - thanks for the quick response. Where do I do that? I went to Storage management and see about 10 work items, but I have no way of deleting the work item or the attachments. I'm the admin of the group too.
John Funk
Oh, I forgot that you are on a Free plan, so there is a good chance you might not able to do the deletions. What you could do is sign up for a trial Standard subscriptions for 30 days and then during that time go in and delete the items. Just be sure to revert back to the Free subscription after you do the cleanup so you don't automatically get charged at the end of the trial.
Sati Hillyer
October 15, 2025
Will try that.
Like John Funk likes this
John Funk
Let us know how it goes.
Sati Hillyer
October 17, 2025
We've tried deleting, where do we see the latest storage usage? I'm not sure if it's going down.
John Funk
Go to admin.atlassian.com - login
On the new left menu, click on Apps and then Sites
Click on the name of your instance
Click on Storage
Sati Hillyer
October 17, 2025
Thanks, is there a way to see all the issues and sort by storage so I can delete the ones that have the most storage?
John Funk
Not out of the box. There is an add-on called Revyz Configuration Manager for Jira that can show you that. You can do a free trial for 30 days for it.
FREE
