How do I get Insight/Asset mapping set up via API?
Chris Thomas
October 7, 2022
Let me start off by saying that I consider myself an advanced amateur with both API and JSON.
Where I am now
By importing CSV files I have a good handle on Insight and have a good idea of how I want to use it. Now I need to automate the import using PowerShell, but I am doing all testing in Postman as the PowerShell Insight module is no longer working.
I have a basic Insight Scheme set up:
I also have the import set up, key generated and working:
I am following along with this document: Insight external imports workflow (atlassian.com)
I am at the point where I am trying to set up mapping.
    "status""MISSING_MAPPING"
My current block:
My problem is that I can't get Insight to import any scheme I try, and I have tried a lot of variations and tried to search all over. I tried the two default schema files and get "
jsonValidationErrors" and when I tried to map my own very simple schema using those as templates, I get the same error.
{"jsonValidationErrors":[{"type":"required","code":"1028","path":"$","sc
hemaPath":"#/required","arguments":["schema"],"details":null,"message":"$.schema: is
missing but it is required"},{"type":"required","code":"1028","path":"$","schemaPath":"#/req
uired","arguments":["mapping"],"details":null,"message":"$.mapping: is missing but it is
required"}],"dataValidationErrors":[],"status":"error"}
If I can get the right format I could take it from there if anyone can help. However if I'm way off base in what I'm doing I would appreciate a pointer.
Right now I don't know what I need or how to format it and the examples are not explained and are very advanced at the moment with no context.
Any help?
Thanks for reading!
Boswell, Richard
October 12, 2022 edited
Here's a skeleton external imports schema and mapping payload:
  "$schema": "https://api.atlassian.com/jsm/insight/imports/external/schema/versions/2021_09_15",
  "schema": {
    "objectSchema": {
      "name": "My schema name",
      "description": "",
      "objectTypes": [
          "name": "My object name",
          "description": "",
          "attributes": [
              "name": "Name",
              "description": "",
              "type": "text",
              "label": true
              "name": "Some other attribute",
              "description": "",
              "type": "text",
              "label": true
  "mapping": {
      "objectTypeMappings": [
            "objectTypeName": "My object name",
            "description": "",
            "selector": "",
            "attributesMapping": [
                "attributeName": "Name",
                "attributeLocators": [
                  "name"
                "externalIdPart": true
                "attributeName": "Some other attribute",
                  "some_other_attribute"
Looking at your error message it seems like you don't have the schema and mapping keys defined.
I'm with you on the docs - I opened a FR asking for better ones ==> https://jira.atlassian.com/browse/JSDCLOUD-11886?filter=-2
